Tagged: 2019 R2, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantYou can use TUI commands within an ANSYS Fluent Journal File, e.g. to change the expression “uprof”: Line 1: /define/named-expressions/edit “uprof” def “x / 1.0 [m]*2.0 [m s^-1]” Line 2: Line 2 is empty by purpose. Otherwise the TUI command from line 1 is not executed completely if you include the journal file.
- Skewness in ANSYS Meshing
