August 25, 2023 at 12:16 pm
SolutionParticipantSee attached for steps in the menu and a sample archive.
1. 2045431.pdf
2. 2045431.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
