June 6, 2022 at 10:32 am
FAQParticipantIf you have an hexahedral mesh e.g. CutCell and you want to introduce prism layer, you can get hanging nodes on the face zone. The reason is the warp quality of the surface mesh. If the quality is worse than 0.1 these cells are splitted. You will get hanging nodes. You can avoid the bad quality by a finer mesh or quality improve algorithm in Fluent Meshing.
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
