Tagged: 2021 R1, FLUENT Meshing/Tgrid, fluid-dynamics, meshing, Watertight, Workflows
April 13, 2023 at 7:32 am
SolutionParticipantFluent Meshing Workflows simplify the graphical meshing process in Fluent Meshing. But they can also be automated for batch mesh by creating a journal file. Please look at the PDF attached to find information on how to create the journal files.
1. 2066525.zip
2. 2066525_Workflow_Automation.pdf
- Skewness in ANSYS Meshing
