How can I assess the results of a simulation if I do not have any experimental or theoretical data to compare to?
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: verification, validation, experimental data
1. 2049173.pdf
- Skewness in ANSYS Meshing
