How can I apply an equivalent thermal conductivity (including convection and radiation) to an unventilated non-rectangular air cavity, based on the calculation from British Standard EN ISO 10077-2.2003?
Tagged: 17, mechanical, static, structural-and-thermal, structural-mechanics
May 15, 2023 at 8:33 am
SolutionParticipantOne way could be to link an Excel calculation to the WB project but an easier way is to calculate the equivalent thermal conductivity in a command snippet and reassign it to the material. Please see .pdf attached for more information.
1. 2040344.pdf
