June 5, 2023 at 7:04 am
FAQParticipantA rotation can be added in Workbench by inserting a remote displacement. You can set one of the rotation to the desired angle and fix other DOFS. More information can be found at Help: Mechanical User’s Guide>Setting Up Boundary Conditions>Types of Boundary Conditions>Support Type Boundary Conditions>Remote Displacement.
