General
General
How can I access CAD assemblies in Fluent Meshing? What are corresponding TUI?
    • FAQFAQ
      Participant
      CAD Assembly is beta feature. In GUI you can update it by using RMB. In console you can use following. /cad-assemblies/update-cad-assemblies |test.scdoc , You just needs to append “|” to the top assembly name and if you need to update specific body under it keep appending using: “|” and further tree hierarchy
