August 25, 2023 at 12:15 pm
SolutionParticipantIn addition to the implemented functions available for calculation of forces and torques in ANSYS CFX, own expressions for the calculation can be defined in ANSYS CFD-Post. How to define the expressions is shown based on the tutorial case “Axial Turbine”. Please also refer to Solution# 2046024 if the setup inside ANSYS CFX Pre is of interest.
1. 2046026.pdf
2. 2046026.zip
- Skewness in ANSYS Meshing
