How can easily create a helical hexahedral mesh? I have a geometry that is extruded helically and require a completely hexahedral mesh.
April 13, 2023 at 7:32 am
SolutionParticipantHelical meshes can be created ub ICEMCFD Hexa by either importing a face mesh for the extruded geometry, or by creating a 2D Hexa blocking and then extruding it. The attached .pdf file gives the steps for a sample blocking of a cylindical tube with a spiral groove cut into it
1. 2059435.pdf
- Skewness in ANSYS Meshing
