Tagged: 19.2, BCs & Interfaces, fluent, fluid-dynamics, materials, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantA very low inter species mass diffusivity can affect the convergence specially in regions with low turbulent diffusivity (viscosity). The diffusive part of the species transport equation can become extremely small compared to convective part and thus might create problems with convergence. A workaround can be to start with a higher laminar mass diffusivity for the species and then slowly drop it.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
