How can a geometry parameter be linked with an object in ANSYS CFX or ANSYS CFD-Post using ANSYS Workbench
Tagged: 18.1, cfx, cfx-pre, fluid-dynamics, General - CFX, link geometry, workbench
August 25, 2023 at 12:15 pm
SolutionParticipantSometimes it is of interest to define a point or dimension that changes parametrically in the geometry and this change needs to be captured in the simulation or in the results. Please refer to the attachments to access the Solution.
1. 2050339.pdf
2. 2050339.zip
- Skewness in ANSYS Meshing
