June 6, 2022 at 10:33 am
FAQParticipantThe following may be used to create a boundary curve to fill or replace a face:
1. Select two vertices and use the Blend command, to create a curve. The default result will be a straight line between the two points.
2. Define tangent conditions at each end using the Guides option within the Blend command.
This will result in a boundary that matches the curvature of the adjacent faces.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
