June 6, 2022 at 10:32 am
FAQParticipantIn geometries with big differences in scale, where the overall dimensions are big but include very thin gaps between bodies, Workbench meshing will detect these gaps as contacts and list them under Connections in Meshing. These contacts will then be transferred to the solver as an interface coupling between the faces.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is the difference between patch dependent meshing and patch independent meshing?
