General
General
How access the “Draw Profiles” panel under Display Contours? Why is the option “Draw Profiles” in the “Contours” panel greyed out?
    • FAQFAQ
      Participant
      The option “Draw Profiles” is only accessible for non-persistent contours plots (legacy fluent postprocessing). Non-persistent contour plots can be generated under “Results” “Contours” with “Edit” instead of “New”, which creates persistent graphics objects. Keywords: fluent, fluent-post, contours, Draw Profiles
