October 17, 2025 at 12:08 pm
SolutionParticipantThis example demonstrates how to use the biphoton wavefunctions generated from two independent nonclassical source models, such as Spontaneous Parametric Down-Conversion (SPDC) Photon Source ( example ) or Spontaneous Four-wave Mixing (SWFM) Microring Resonator Photon Source, ( example ) as the input to a circuit in qINTERCONNECT designed to model Hong-Ou-Mandel (HOM) interference. The visibility of the HOM interference is calculated, which is directly related to the indistinguishability between the signal photons from each source.
Read the full article here: https://optics.ansys.com/hc/en-us/articles/19384886020627
- Hong-Ou-Mandel Interference Between Independent Heralded Photon Sources
- Large-Scale Metalens – Ray Propagation
- Integrated microlens and grating coupler for photonic integrated circuits
- Diffraction-Based Overlay Metrology System Design
- Spontaneous Four-Wave Mixing (SFWM) Microring Resonator Photon Source
- Spontaneous Parametric Down-Conversion (SPDC) Photon Source
- Exit Pupil Expander with 1D-2D Gratings
- Volume Holographic Grating
- Ring Modulator
- Small-Scale Metalens – Field Propagation
