Having trouble with sweep meshing producing poor quality mesh. If I try to fix it with edge controls, the body does not mesh at all. How can I go forward?
Tagged: 18.1, fluid-dynamics, General, meshing, Multizone
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: sweep, multizone, sweepable, map
1. 2050742.pdf
- Skewness in ANSYS Meshing
