HARDWARE INFORMATION DOCUMENT Updated at ANSYS release 2022.Rx This document is designed to help you get started with your hardware selection. ANSYS is vendor neutral as we partner with all of the major hardware vendors. At the end of this document are some specific hardware model recommendations based on the vendor that you normally purchase from. Please visit the vendor’s website and attach any specifications to your SR for further review. Thank you ANSYS Support
March 17, 2023 at 1:11 pm
SolutionParticipantPlease download the attached Hardware Information Document.
1. 2041327-R2022.x-hardware-all.pdf
