Tagged: align, anchor, Ansys Discovery, assembly, Assembly Tool, Discovery Geometry, Multi-part assembly, orient, rigid, tangent
May 20, 2025 at 2:42 pm
Watch & Learn
ParticipantAnsys Discovery in addition to its direct modeling capabilities consists of great features under Assembly tool that can help you create single part orientation or multi-part assembly. In this video series we will see how it’s very easy to implement it in your workflow for creating assembly conditions.
Assembly tools can be accessed from the Design Tab in Discovery interface, and it consists of various options like Orient, Align, Tangent, Anchor, Gear or Rigid for creating the assembly condition.
Note: These video tutorials have Chinese (simplified), Japanese and English subtitles embedded in them, please activate them by navigating to the gear icon (⚙) and choose the language from captions. / 注意:这些视频教程嵌入了中文(简体)、日文和英文字幕,请通过导航到齿轮图标 () ⚙ 并从字幕中选择语言来激活它们。/ 注意: これらのビデオチュートリアルには、中国語(簡体字)、日本語、英語の字幕が埋め込まれています。ギアアイコン(⚙)に移動して、キャプションから言語を選択することで、字幕を有効にしてください。
Assembly options: Single part orientation
In this tutorial, we will see how you can orient a single part with respect to the world origin. We will be using the assembly tools – align and orient to do so.
Assembly options: Multi-part assembly
In this video we will see how you can assemble components in an Assembly. We will see how you can anchor a component, use align tool to align other components to the anchored part, either using faces of the geometry with or without the offset or using planes.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Working with Components
- FAQ – Share Topology is now available in Discovery 2021 R2
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
- Ansys Discovery: Automatic External Volume Enclosure
