Tagged: 18.2, designmodeler, fluid-dynamics, General, Preprocessing: Geometry
June 5, 2023 at 7:05 am
FAQParticipantWhen an enclosure is used to form a domain, the exterior boundary of the enclosure will be automatically exported as a named selection, even though we already have assigned another NS to the same surfaces. We therefore need to change the default setting under the Enclosure operation, “export enclosure” to “No”
- Skewness in ANSYS Meshing
