Getting Error while specifying special characters in ‘ANSYS Client Licensing Settings 2021 R1’ or even IP address of server machine Error: Server3 cannot have special chars
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2065469.pdf
