Geometry will not share topology or Boolean unite with adjacent bodies, fluid volume extraction will not work, etc. What should I do?
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General, geometry
May 15, 2023 at 8:33 am
Solution
ParticipantPlease see attached document for solution. Keywords: share topology, boolean, geometry repair, volume extraction
1. 2049203.pdf
- Skewness in ANSYS Meshing
