November 2, 2022 at 9:16 am
Watch & LearnParticipantIn this video we will learn how to edit the bodies without merging the body together. In Pull, Blend operations you have an option of “No merge” which helps in modelling operations without merging into other connected bodies. Please watch the video tutorial for more information.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- FAQ – Share Topology is now available in Discovery 2021 R2
- Ansys Discovery – Detect Tool
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
