Tagged: acp, acp-pre, ansys-mechanical, chassis, composite, Formula Student, formula-sae, fsae, FSAE Car, Monocoque, roll-cage, Student Team
June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video shows a quick preview of the series of videos focused on analyzing a Formula SAE monocoque chassis under torsional loading conditions. This video series is perfecet for student teams competing in the Formula SAE competitions, seeking to optimize the weight and stiffness of their chassis through the use of composite monocoque technology (ie: by moving away from welded tubular chassis). For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
