From what reference do the kinetic parameters (e.g. pre-exponential factor and activation energy) for hydrocarbon mixtures in Fluent come from?
Tagged: Flamelet Models, fluent, fluid-dynamics, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantWestbrook and Dryer, “Simplified Reaction Mechanisms for the Oxidation of Hydrocarbon fuels in flames”, in Combustion Science and Technology vol. 27, 1981 Important: See also the comment and correction from T.P.Coffee “On simplified Reaction Mechanisms by Oxidationof Hydrocarbon Fuels in Flames by Westbrook and Dryer”, in Combustion Science and Technology, vol. 43, 1985
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
