April 29, 2026 at 12:22 am
FAQParticipant
How is SPH Adaptive Size different from standard SPH in Ansys FreeFlow?
In standard SPH simulations:
- All SPH elements have the same size and spacing.
- Resolution is fixed throughout the simulation.
- Improving accuracy requires globally reducing SPH elements spacing.
With SPH Adaptive Size:
- Element size can change locally during simulation.
- Resolution is higher only in selected regions or near boundaries.
- The overall number of elements can be significantly reduced compared to a uniform fine-resolution model.
- As a consequence of a lower number of SPH elements, the simulation execution time can be reduced.
Access more FAQs and Tips in the page:
Ansys FreeFlow™ smoothed-particle hydrodynamics (SPH) simulation software
Janaina Oliveira
Technical/Product Publications
- Skewness in ANSYS Meshing
