Tagged: ansys-mechanical, ansys-student, Formula SAE Chassis
June 6, 2022 at 9:30 am
Watch & Learn
ParticipantIn this video, you will learn how to apply loads & boundary conditions on chassis models and solve for stress and deformation. Torsion and cornering test will be carried out. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
