For the PIPE289 element, how can the distance between the graded section nodes in the through-thickness direction be measured?
June 6, 2022 at 9:58 am
FAQParticipantOne can do the following:
1. Use SECPLOT,id,2 to plot the section ID with section node numbers. Make node of two section node numbers that reflect the distance you want to measure
2. Use SLIST,id,,,FULL to list the section properties, including section nodes. The section nodes will be given the Y and Z coordinates.
Find the two section nodes identified in step #1 above, then you can easily find the distance between them knowing the [Y, Z] coordinates, which will give you the cell size.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
