For pre-stressed Workbench LS-DYNA (Static Structurl links to Workbench LS-DYNA), solve in foreground (My Computer) for Static Structural may fail with below error in Solver Output: For distributed solve: ANSYS LS-DYNA *** FATAL *** CP = 0.172 TIME= 10:29:30 Distributed ANSYS is not valid for this product. For shared memory parallel solve: ANSYS LS-DYNA *** FATAL *** CP = 0.156 TIME= 10:32:20 Parallel capability is not valid for this product. For serial solve: ANSYS LS-DYNA … *** ERROR *** CP = 0.438 TIME= 10:33:48 The element option SOLID185 was either not ordered with this ANSYS installation or the appropriate product was not selected for this session. Contact your ANSYS support person for more information.
April 5, 2023 at 2:32 pm
FAQParticipantIn Workbench (18.x or 19.x), go to Tools > License Preferences > Solver tab, move ANSYS LS-DYNA down to the bottom or below all products enable MAPDL solver (e.g. ANSYS Mechanical Enterprise), then Apply. Or just click “Reset to Default” if product orders are not customized on license server. Reopen Mechanical, make sure ANSYS LS-DYNA appears at end of Mechanical window title, e.g. Multiple Systems – Mechanical (ANSYS Mechanical Enterprise – ANSYS LS-DYNA).
