For FLUID116 can mass flow rate be specified using a tabular load that is spatially varying (SFE,,,HFLUX)?
Tagged: 18.2, apdl, mechanical-apdl, static, structural-and-thermal, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantNo, for FLUID116 the thermal boundary condition of flow rate is only supported for tabular loads with TIME as the primary variable. See Table 2.11 in the Thermal Analysis Guide or this ANSYS Help link: help/ans_the/Hlp_G_THE2_6.html#thetabbctlm6700
