Tagged: 19.1, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe coiled surface can be modeled as contact and target. But it is better to have the spring sliced – multibody part and then define the self contact/ contact surface at relevant coils. If whole surface is selected then the update of the contact definitions while solving may become complicated.
