Licensing
Licensing
Followed ANSYS RSM 19.2 User’s Guide 2.2.4. Configuring a Network Installation of RSM, to set an system environment ANSYS_RSM_APPSETTINGS_DIR in /ansys_inc/v192/Config/tools/linux/rsm_env_profile as below to point to a local RSM application settings configuration directory: export ANSYS_RSM_APPSETTINGS_DIR=/tmp/rsmconfig Moved /ansys_inc/v192/Config/Ans.Rsm.AppSettings.config file to /tmp/rsmconfig folder, tried to start RSM 19.2 Launcher, either in service mode (daemon run as rsmadmin) or no service mode (as regular user), got error said: Setting environment variables from ‘/ansys_inc/v192/RSM/Config/tools/linux/rsm_env_profile’ Starting RSM Launcher Service … RSM Launcher Service start failed. Please check the Logfile for Errors Unhandled Exception: System.TypeInitializationException: An exception was thrown by the type initializer for Ansys.Rsm.Utilities.ApplicationConfiguration —> System.IO.FileNotFoundException: Settings file not found in /ansys_inc/v192/RSM/Config ……
    • FAQFAQ
      Participant
      Create a subfolder named v192 under ANSYS_RSM_APPSETTINGS_DIR specified directory (/tmp/rsmconfig), move the Ans.Rsm.AppSettings.config file to this subfolder (/tmp/rsmconfig/v192). Also applies for R19.0 or R19.1 (corresponding subfolder v190 or v191).
