May 27, 2024 at 2:18 pm
SolutionParticipantA vast majority of industrial flows are turbulent. While conditions at boundaries may be steady, shear action near walls and other velocity profiles lead to time-dependent pressure and velocity fluctuations transported by and affecting the mean path of the fluid. These “turbulent” fluctuations span a wide range of length and timescales. As a result, computational demands for exact solutions of industrial turbulent flows far exceed available computing resources.
In Discovery, the k-omega SST turbulence model is appropriate for most cases and is the default for both time-dependent and steady-state simulations. Additional turbulence models are available and can be modified based on your simulation requirements. Refer the attached document to learn more about them.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Quick Tip- Applying Thermal Conductance
- Structural Simulation using Bolt Idealization
