June 6, 2022 at 8:45 am
Watch & LearnParticipantIn this video, you will learn how to finish the solver setup in ANSYS Fluent for flow through a y-duct. You will learn how to set the solver discretizations, set the convergence criteria, create a report plot of the outlet temperature and finally initialize and run the calculations. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- Skewness in ANSYS Meshing
