June 6, 2022 at 10:51 am
Watch & LearnParticipantIn this video, you will learn how to model the geometry for flow through a y-duct of circular cross section. You will learn how to sweep a circular surface along a path, mirror the object across a plane, and setup named selections before exporting to ANSYS Fluent. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
