FluentLM License Manager Beginning with the release of the R18.0 ANSYS Suite, the FluentLM License Manager will no longer be supported by any ANSYS software releases.
Tagged: FLUENT - SYS, fluentlm, Installation/Licensing/Systems, legacy, licensing, Other
January 25, 2023 at 7:28 am
FAQParticipantIf you are running any ANSYS products using the FluentLM License Manager will need to migrate to the ANSYS License Manager. Please contact your ANSYS Account Manager for more information. Legacy products can still be used with the FluentLM License Manager, for example, Gambit, Airpak.
