Tagged: 15, fluent, fluid-dynamics, RANS Models, turbulence
June 5, 2023 at 7:06 am
FAQParticipantYes, it is possible to visualize the F1 and F2 blending functions for SST model Simply use solve/set/expert in TUI and answer Yes to the question “Keep temporary memory from being freed”, perform at least one iteration and then you are able to see an extended list of the postprocessing options in the “Display Contours” tab under “Turbulence”.
- Skewness in ANSYS Meshing
