Tagged: 2021 R1, fluent, FLUENT - SYS, Font, graphics, gui, Installation/Licensing/Systems, Other
March 17, 2023 at 9:00 am
FAQ
ParticipantThis is a common issue with Fluent users. Fluent GUI follows the Display setting of Operating System. The default layout of display on your machine would be set to 125 % or 150% To change the default layout: On the Desktop > right click > Display settings In Display settings > change the resolution to 1920×1080 and scaling settings (Scale and Layout) to 100%
