Fluent giving error as ‘invalid argument’ while opening case file. How to fix or repair this case file?
Tagged: 17.2, fluent, fluid-dynamics, General - FLUENT
August 25, 2023 at 12:15 pm
SolutionParticipantSometimes files saved in old versions may give error while opening. The files can be opened in text editor. The invalid arguments can come from surface monitor command such as shown in attached image ‘2046093.jpg’. You can delete such commands and save the file with new name. Now you can read this file in Fluent.
- Skewness in ANSYS Meshing
