Fluent crash with error as: The fl process could not be started. cells…………….,MPI Application rank 0 exited before MPI_Finalize() with status -1 **************************************************************************** * hwloc has encountered what looks like an error from the operating system. * * Socket (cpuset 0xfff000ff) intersects with Socket (cpuset 0x000fffff) without inclusion! * Error occurred in topology.c line 940 *
Tagged: 18.1, fluent, fluid-dynamics, General, General - FLUENT, parallel
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: error, mpi, hwloc, socket, crash
1. 2050743.pdf
- Skewness in ANSYS Meshing
