Fluent 19.2 is installed under /usr/ansys_inc (by default) with symbolic link of /ansys_inc created pointing to /usr/ansys_inc. Launching Fluent 19.2 by running /ansys_inc/v192/fluent/bin/fluent, you received the below error in the Fluent Console: Error: cx-run: exec failed. Error Object: () Error: eval: unassigned variable Error Object: rp-3d? version> Error: eval: unassigned variable Error Object: rp-3d? And below error in Linux terminal: exec: No such file or directory
- Error: eval: unassigned variable Error Object: rp-3d? And below error in Linux terminal: exec: No such file or directory" target="_blank" rel="nofollow" title="LinkedIn">
- Error: eval: unassigned variable Error Object: rp-3d? And below error in Linux terminal: exec: No such file or directory" target="_blank" rel="nofollow" title="whatsapp">
- Error: eval: unassigned variable Error Object: rp-3d? And below error in Linux terminal: exec: No such file or directory" target="_blank" rel="nofollow" title="reddit">
- Error: eval: unassigned variable Error Object: rp-3d? And below error in Linux terminal: exec: No such file or directory" target="_blank" rel="nofollow" title="facebook">
April 5, 2023 at 2:32 pm
FAQParticipantOption #1: Check PATH environment variable, remove obsolete directory ending with /ansys_inc/v192/fluent/bin (such as /usr/local/ansys_inc/v192/fluent/bin), or change it to /usr/ansys_inc/v192/fluent/bin or /ansys_inc/v192/fluent/bin in PATH environment variable. Option #2: launch Fluent 19.2 from /usr/ansys_inc/v192/fluent/bin/fluent, rather than /ansys_inc/v192/fluent/bin/fluent.
