FLEXnet Licensing Error -97: The desired vendor daemon is down. 1) Check the lmgrd log file, or 2) Try lmreread.
March 17, 2023 at 9:01 am
FAQParticipantThe vendor daemon, ansyslmd.exe, is not running. Check the lmgrd.log file for specific error messages.
