FlexNet Licensing error:-18,147 Product fails to obtain a license even though lmstat shows the specific increment exists.
March 17, 2023 at 9:01 am
FAQParticipant** Internal Only as relates to 2019R2 prerelease ** Ansys EBU products will require CVD licensing at release 2019R2. If the customer has valid “ansoftd” features, they will no longer be recognized and a new “ansyslmd” license issued.
