File>Export>Mesh command is not available in Fluent Meshing when run in a Workbench project
- Export>Mesh command is not available in Fluent Meshing when run in a Workbench project" target="_blank" rel="nofollow" title="LinkedIn">
- Export>Mesh command is not available in Fluent Meshing when run in a Workbench project" target="_blank" rel="nofollow" title="whatsapp">
- Export>Mesh command is not available in Fluent Meshing when run in a Workbench project" target="_blank" rel="nofollow" title="reddit">
- Export>Mesh command is not available in Fluent Meshing when run in a Workbench project" target="_blank" rel="nofollow" title="facebook">
Tagged: 2019 R1, FLUENT Meshing/Tgrid, fluid-dynamics, General, Watertight, Workflows
March 17, 2023 at 8:58 am
FAQParticipantThis is a known limitation in versions 2019R1 and 2019R2. The panel won’t be available when you have created a parallel poly-hexcore mesh inside the Watertight geometry workflow, with option “Enable parallel meshing” activated The command is available in serial, and you can save a mesh when working with Fluent Meshing standalone You can work around this issue by transferring the mesh into the solver, and exporting the case file
- Skewness in ANSYS Meshing
