June 6, 2022 at 9:30 am
Watch & Learn
Participanthttp://bit.ly/1lnB3ti Complete simulation process for the FEA simulation of a composite wind turbine. The video describes all the steps from geometry to failure analysis with a focus on the definition of the laminate composites. The efficiency of the workflow is the result of the combination of ANSYS Mechanical for the general FEA aspects with ANSYS Composite PrepPost for the detailed definition and analysis of the composite model.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
