September 26, 2022 at 9:44 am
FAQParticipantFAQ – Share Topology is now available in Discovery 2021 R2
Share Topology option is now available in Discovery 2021 R2 in the Prepare Tab.
Share Topology helps to identify the geometrical entities that get shared among bodies that are in contact. It helps to achieve conformal mesh where bodies are connected and is the way to be certain that the intersection of bodies is meshed properly.
For now Share Topology exists in Discovery but only limited to applications that can be transferred to Mechanical/Fluent/WB. It is not intended to be used in Explore and Refine mode.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- FAQ – Share Topology is now available in Discovery 2021 R2
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
