“Failed to install Prerequisite: Visual C++ 2017” “The installation will continue, but the product will not run without the prerequisite” “Error: Unknown error code 0x666 (1638) returned from installation”
January 25, 2023 at 7:28 am
FAQ
ParticipantInstall to a non-default location. ex: c:AnsysEM
