Facing the issue while running the case with the Battery module, ECM model. The run has stopped due to the following error? Ida solver failed when calling echem submodel in a normal call: Vp=1.924120 Vn=-0.00029 IDA returns error code: -1 ida_check_flag<0! in p2d function
April 13, 2023 at 7:33 am
- Skewness in ANSYS Meshing
