November 2, 2022 at 9:16 am
Watch & LearnParticipantIn this video you will learn how you can export your simulation to flagship products. You can transfer Discovery data to another Ansys application. For example, if you are a designer using Discovery, you may want to export your simulation and send it to an analyst for further analysis in Mechanical, Fluent or HFSS.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- Applying Thermal Conductance
- Structural Simulation using Bolt Idealization
- Discovery Quick Tip- How to Export to Fluent
