Tagged: 18, cfx, fluid-dynamics, Heat Transfer and Radiation, heattransfer, Other
May 15, 2023 at 8:32 am
SolutionParticipantThe use of an additional variable based on a transient time-averaged variable allows for export of surface data. In addition, live solution monitoring of the transient time-averaged variable can be performed.
1. 2050371.zip
2. Transient%20average%20profile%20of%20HTC.pdf
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
